Previous in Forum: Ratings for Socket Welded Fittings   Next in Forum: Saddle Designs for Pressure Vessels
9 comments
Hydraulic Calculation for Firefighting System
11/24/2008 1:44 AM
dose anyone help me. how to do hydraulic calcualtion for firefighting sytem.
thanks in advance
sulemanaie
Good Answers: 101
Re: Hydraulic Calculation for Firefighting System
11/24/2008 8:46 PM
It's usually done with specialized pipe flow design software. You can use the Darcy-Weisbach equation to work it out though. Basic principle is this:
Required discharge flow per sprinkler head X total number of sprinkler heads on all levels of building = minimum required volumetric flow rate.
Required service pressure for 1 sprinkler head + total pressure losses in pipelines and fittings + total vertical height of pipes = required pressure head.
11/24/2008 10:46 PM
dear thank you very much.
a bounch of thanks in advance.
suleman
ADMIN: Deleted Content
From the Rules: Do not post personal contact information on the forum space. You can share this information via the forum's internal messaging system.
11/25/2008 5:26 AM
sulemanie,
These calculations should be done by someone who is familiar with the process or at least checked by someone who has done this professionally. A fire-fighting system must be designed properly. The results of an improper design can be deadly. I would recommend that you seek paid professional guidance with this endeavour.
If you want to know what God thinks of money, just look at the people he gave it to. - Dorothy Parker
11/25/2008 5:35 AM
i work for mep contracting compnay in dubai. i know baisics of hydraulics calculation.
i need in details.
if anyone helps me out?
thanks in advance.
suleman
11/25/2008 5:43 AM
I too am a hydraulic engineer, however fire fighting system are a highly specialized field and the consequences of an error are a bit deadlier than in other areas. I would still recommend seekingthe services of someone who specializes in this field.
Good Answers: 19
11/25/2008 10:23 AM
The information you need is in NFPA (National Fire Protection Association) Standards 13 and 14. Dubai will recognize this standard and accept it. Get information on buying copies at www.NFPA.org.
11/25/2008 7:17 AM
Hi,
The Epanet software will be helpfull for you.
You can find it in the EPA website
http://www.epa.gov/NRMRL/wswrd/dw/epanet.html
Regards,
Ernesto
01/22/2009 6:30 AM
thanks alot
01/21/2010 8:31 AM
Dear sir,
there r two methods of fire automatic sprinkler calculations
1 the fully hydraulic calculations clear with example in NFPA 13
2 the precalculated method in the LPC code which is easier and more simple
Ala'a
Register to Reply 9 comments
AlaaSkyline (1); Anonymous Poster (1); d_m_rosenberg (2); DVader1000 (1); ernesto1962 (1); Ried (1); sulemanaie (2)
