Hey - I'm putting together a list of safety rules for our new lab. Does anyone know the lower frequency limit for RF burns? My last one was 30 years ago on a school lab project.
Yeah - I think 3MHz was what burned me - it was a single stage class A tube amp, and I touched the plate terminal.
I'm not concerned about burns from antennas - we don't have any. But we do poke around in the innards of some high power (500w) switching power supplies that operate in the 100's of KHz.
It should perhaps - but it doesn't. I'm not interested in radiation effects, but rather the burn you get when you touch an RF circuit. I guess my question wasn't clear enough.
Good luck and please let me know if these are what you want.
A far as I am aware there is no "safe" lower frequency limit for RF burns.
If you are concerned about contact rather than radiation initiated burns, then its important to recognise that the burn is a reaction to the current flowing through that part or parts of the skin which has been introduced into the "live" circuit under examination.
Though burns can occur also when coming in contact with components operating at elevated temperatures around and above 50Deg C.
Ionising radiation is the culprit for causing RF burns, and there are numerous documents to be found under (Australian) OH&S regulatory documents regarding this.
Being an old radio techie I'll give you this advice which I give to all my apprentices.
Always keep one hand in your pocket whilst working on "live" equipment. It'll keep you from lighting up your back teeth if you do come in contact with something "hot"...
I learnt that from working on (steam powered) valve two way base radio stations as a boy apprentice. That of course was a time when people died on the job and were proud of it!
Hope that helps
Cheers
Pez
