Previous in Forum: corrosen allownce   Next in Forum: Boolean Convert to Integer value
Biomass, Moisture and impurities control
11/25/2008 2:41 AM
Hi, I'm wondering if anyone out there could share with me how are:
1. moisture content are controlled and maintained in an optimum level for a wood chips used as biomass fuels. I'm interested in looking at cheap solutions, with effective results.
2. methods of impurities control such as, fungus, insects, gravels.
I'm living in a tropical country, so moisture and impurities are a major issue from me. The above 2 issues, comprimises my burning efficiency and weight input.
Re: Biomass, Moisture and impurities control
11/26/2008 2:10 AM
Welcome to CR4 devanns,
I don't know about the second issue but only the gravel is not biomass.
On the first issue apply a vacuum to your feed stock and the water will boil off at much lower heat.
Brad
11/26/2008 10:16 AM
Hi Brad,
Thanks for the response.
Actually, I'm trying find ways to control moisture content in a biomass product called Palm Kurnell Shell (PKS), which is a waste product from Palm fruit bunch.
My stockpile is located in a tropical country which expalins why I'll need to control moisture within 12% or less.
As for the impurities, fungus, insects and stones (size ranging from 30~40mm diameter) is pain.
Vacuum sounds like a plan, but how do I apply vacuum to a stockpile, which is ranging from 25000~30000ton. I have power limitation, because my stockpile is on an open field. But I enough manpower, anyway we can make them useful?
For the insects and fungus, I'm planning on fummigation. But how do I get rid of rocks for a stocpile that huge.
Desperately need an answer.
BR//Devan.
11/26/2008 2:08 PM
How about a trommel screen for the rocks. Use a trommel screen that has a 30 - 40 mm screen. Is the product larger or smaller than the 30-40 mm?
Are you turning the pile? This should help to control the moisture. Everytime you turn the pile you lose moisture. What is the end product?
I work in the recycling/compost/mulch industry we experience similar problems when making our products.
Register to Reply 3 comments
devanns (1); staceyroberts (1); U V (1)
