Problem - Windows Setup disk will not recognize new SATA hard drive for installation.
My system info:
Win XP Pro Service pack 2. Iwish to use the OEM Windows install CD, provided with my PC. My goal is not to pirate, but simply get a fresh install, then rebuild, and eventually, have a dedicated back-up drive, and only 1 bootable windows drive.
New drive is Maxtor 500GB
What I have done:
I have created a primary and logical partition on the new drive, and it is functional within windows. I have also physically removed the existing C drive, and connected my new drive to port 0; booted from Win CD, and proceeded thru setup. Win Setup still cannot locate any drives to load OS to.
Oddly enough if I leave my USB drive plugged in, Widows setup does recognize the USB drive as a valid install destination, although it is only 512MB!
Summary:
I must be missing something very simple, I am more familar with IDE drives, and still am not sure if I ever set the new drive as "Master" (or if this is even necessary) because there is not a M-S jumper on new drive. I can see it within the BIOS and it is shown as slave.
Any help or direction to good information will be appreciated. If I do not reply to your post, it means I killed my PC, not that I fixed the problem. Hopefully "I'll be back"
