Previous in Forum: ss 304 vs ss316L   Next in Forum: water monitoring
Check Valve Position
11/26/2008 8:45 AM
Any body please tell me about check valve position. Can we place in vertical.
Thanks
Vinod
United States - Member - BoatMan
Re: Check Valve..Position
11/26/2008 8:51 AM
It depends on the check valve and application. What type of piping and what material are you talking about. A little more info Please.
"Only one life, will soon be past, only what's done for Christ will last." Dale Linson
Re: Check Valve Position
11/26/2008 1:55 PM
You can place it in the vertical, but only as long as the flow is going up. If you have it pointing down, then the check valve will not work very well. The check in the valve will want to fall forward at zero flow due to gravity and if you only have a little reverse flow, it will not be enough to seat the check in its seat and stop the reverse flow. Even if you have a spring loaded check valve its not a good idea since the head of fluid could force this open.
So to answer your question, yes and no.
