Previous in Forum: Problems with a Motor Burning-up   Next in Forum: S.B. Sahoo
Full Vacuum Condition?
11/27/2008 12:49 AM
Which pressure, temperature condition are held under full vacuum? whether temperature govern vacuum condition?
Re: Full Vacuum Condition?
11/27/2008 2:54 AM
There is a common missconception that if you keep pumping you can get harder and harder vacuums.
The pressure? In absolute terms ...zero!
In practical terms in free air on the Earths surface the pressure is 1 atmosphere acting to collapse your pressure vessel.
Any pump can only pull 1bar ... it may well be able to generate a positive pressure of several bar.
A vacuum is nothing at all...if you heat it up it's still nothing so it's conditions will not change.
Reply to Forum Thread
