Previous in Forum: Miller big blue 600x   Next in Forum: refer a counter with surge protection
ASI modules
11/28/2008 12:12 AM
CAn anybody tell about the company IFM and the DInput modules and the difference between SAC boxes or what is ASI modules.??? I know a lil bit about PLC communication and all...
Avoid plastic... LIve Green....Get automated..Try new things...don't forget basics...!!!
Australia - Member - New Member Engineering Fields - Electrical Engineering - New Member Engineering Fields - Electromechanical Engineering - New Member
Re: ASI modules
11/29/2008 7:03 AM
What do you want to know about IFM? The company is IFM-Efector and have some good sensors.
Not sure what a SAC box is but AS-i is a device based two wire master slave network. Check out http://www.as-interface.net/ for more on AS-i.
tooz
Re: ASI modules
11/29/2008 1:12 PM
Also, this is the website for IFM http://www.ifmefector.com/ifmus/web/home.htm. AS-i is a device-level network like DeviceNet. You need a communications module in your PLC rack to talk to the I/O modules in the field. You transfer data to and from the card to read and write to the I/O modules. Once you have the mapping done (it is done differently for different comm cards) then it just like writing coils and reading contacts in your logic.
Do this. Don't do that. Can't you redesign?
Register to Reply 2 comments
