Previous in Forum: why the transformer should not meggered with PI(polarization index) mode or meas   Next in Forum: installing transformer
Induction motor efficiency
11/29/2008 6:42 AM
Dear All,
If the full load effieciency of 3 phase delta connected squirrel cage IM is 90%,
then What is the effieciency at 40% or below load?
Thank you in advance
Good Answers: 804
Re: Induction motor efficiency
11/30/2008 12:04 AM
Only the motor manufacturer can answer that and it will vary by motor design. But generally, the efficiency only drops a few percent even in the worst cases.
Belgium - Member - New Member
Good Answers: 21
12/01/2008 6:13 AM
Normally you can ask (or buy) a motor type test report. In this report there are different graphs.
1) tests at no-load (testing while the supply voltage increases)
  • cos fi against motor voltage
  • input electrical power against motor voltage
  • motor current against motor voltage
2) locked rotor tests (testing while the supply voltage increases)
  • rotor torque against motor voltage
3) load characteristic tests (supply voltage equals nominal motor voltage and mechanical output power increases from 0 to 200% of the nominal motor power)
  • cos fi against motor output power
  • efficiency against motor output power
  • slip (shaft speed decreasing ?) against motor output power
  • motor current against motor output power
  • input electrical power against motor output power
4) control characteristic tests (shaft torque equals to nominal motor torque and the supply voltage increases from 80% tot 120% of the nominal motor voltage)
5) cooling down or warmin up test ( at nominal motor torque and nominal motor supply voltage)
  • temperature of the windings against time
6) a motor torque against motor speed graph
7) a spectrum of the motor sound generating
8) a spectrum of the motor vibration generating
As you can see, there is a lot of documentation about a motor. These tests are made up for every model of motor (output power, number of poles, frequency).
Good luck
(without any form of warrenty)
Reply Score 1 for Off Topic
12/02/2008 5:38 AM
In a squirrel cage IM if you decrease the load the rotation speed will about the same. That means that the mechanical loss also will be the same so it will consume higher part of energy consumed by the motor. At the same time the motor current will be lower so both the iron loss and the copper loss will be lower. If you measure the power consumption of a free-running motor, that will be the motor's own loss ("zero efficiency"). Now you can draw a diagram and can interpolate between the free-running and the full load.
Aged man is not old man...
JRaef (1); Qqberci (1); rudy.leurs (1)
