Previous in Forum: filter location ?   Next in Forum: Maximum Bending Stress and Pressure Vessel Design
B F Gas Calorific value
12/01/2008 5:39 AM
We have observed that with same gas flow, some times Boiler's steam generation get reduced drastically. It is a clear indication of lower BFG calorific value.
I would like to know why it happens?
Good Answers: 143
Re: B F Gas Calorific value
12/01/2008 7:43 AM
You don't provide enough information to give a clear picture, but I suspect you're using some sort of process gas (for example, coke oven gas shows this kind of variation) and the calorific value is varying as a function of what is happening in that process. You need to add a higher heat content gas (for example methane) and measure the mixture for a steady heat content. Several companies make reasonably priced instruments for continuously monitoring heat content.
Here's one that could be used (though it's designed for air/fuel ratio, you just have to use it sort of "backwards")
http://www.directindustry.com/prod/ametek-thermox/air-demand-wobbe-index-analyzer-14271-54430.html
Reply to Forum Thread
