Previous in Forum: OSHA Arc Flash Standards   Next in Forum: genrotor inqueri
8 comments
total load calculation
12/01/2008 7:14 AM
dear all
my question is my total kw 2880 so & my this load is cuntines 24 hrs
so what is the my months units ?
Re: total load calculation
12/01/2008 10:58 AM
No clue what you are asking for.
12/05/2008 12:25 AM
Hi,
there is no relvance for your 24 hours. If we can presume 2880 kW is 24 hours consumption, then what is the supply volatge. If it is 415 V, 3 Phase supply, then the Current can be determined. Accordingly the current rating for individual load can be determined.
Regards,
N.Suresh
12/08/2008 11:17 PM
HI DEAR
THANKS FOR REPLAY
MY SUPPLY VOLTAGE IS 415 VOLT AC 3 PHASE AND P.F. 0.8 SO PL.REPLAY
THANKS & REGARDS
JIGAR SOLANKI
12/10/2008 5:46 AM
How are you ?
sir if your voltage is 415V and P.f is 80% so what do you need to know?
but as far as your given data is concerned or my understanding is to unearth the power: 330 +_ 2 watts.
Regards,
ahsum haleem
polymer engineer
12/10/2008 5:54 AM
if you want to know current is o.8 A.
ahsum haleem
polymer engineer
12/10/2008 5:58 AM
total load is 518.5 0hms
ahsum haleem
polymer engineer
12/10/2008 6:05 AM
hi,
sir try it!
kVA = volts (line to ground) X amps X 3 (three-phase system) ÷ 1,000
ahsum haleem
polymer engineer
12/08/2008 11:43 AM
Dear,
KW is the unit for rate of doing work i.e. power so 2880 per 24 hrs, it isn't concerned.
1. calculate current I which is equal to voltage V / resistance R
2. p= I.I R now put your values I=P/(R.I) this gives you current utilized through whole powersTHEN MULTIPLY THIS I by per unit cost
ahsum haleem
Polymer engineer
ahsum haleem (5); Anonymous Poster (1); solanki_jigar (1); wareagle (1)
