Previous in Forum: what is the configuration of an Electronic Earth pit.   Next in Forum: wot is a charge?
Capacitor Calculations
12/03/2008 7:43 AM
Run Capacitor
I have a swimming pool pump rated at 0.75kw
it runs off 220vac power 50 hz
How do I calculate the run capacitor value?
I require the calculation for other ac motors as well
the capacitor remains in the circuit all the time.
The existing capacitor marking are burnt beyond recognition.
New Zealand - Member - Kiwi
Good Answers: 29
Re: Capacitor Calculations
12/03/2008 3:56 PM
Best ask the pump manufacturer. It's not something you can calculate, and every motor is different.
paulusgnome
12/04/2008 1:25 AM
Thanks for the quick reply.I will try and contact the pump manufacture.
I managed to fimd the following.
A rule of thumb has been developed over the years to help simplify
this process. To select the correct capacitance value, start with 30 to 50µF/kW and adjust the
value as required, while measuring motor performance.
12/04/2008 9:10 AM
I asked the same question about 6 months ago and the best I got was 25Mf / hp which roughly coincides with what you have found elsewhere.
Chas
12/07/2008 11:57 AM
Mf is incorrect. Capital M means Mega, or one million. I don't believe anyone has produced a capacitor anywhere near a Million Farads...
if you don't know how to use µ, then please write out micro-
12/05/2008 3:03 AM
Thanks
I will let you know when I get some results.
Gav
Anonymous Poster (2); dkwarner (1); Gav (1); Paulusgnome (1)
