Previous in Forum: ASTM EQUIVALENT   Next in Forum: Gold in exchange for Europium
Drawing Curvature and Taper
12/03/2008 10:22 AM
Hi,
I want to fabricte a shell of 800mm ID and 750mm Height from 1.6mm thk steel sheet.Iwould like to know how to make the Dvelopment drawing ( other then reactangle PI X D calculation) to developthe shell in rolling process to achieve .5mm tolerance. One of our vendor send the development drawing with curvature on the top and the bottom edges along with the taper on the sideedges . but i really dont understand why they included this curvature and taper?
The best way to escape from a problem is to solve it ; The full use of today is the best preparation for tomorrow:
Good Answers: 101
Re: Shell Developent drawing
12/03/2008 11:26 AM
I suggest working with a local steel fabrication company, who has the capability of rolling your piece. They will be able to tell you what is needed, and help you along your way.
Good Answers: 143
Re: Drawing Curvature and Taper
12/03/2008 12:10 PM
Draw what you want delivered to your loading dock. The development drawing is the vendor's concern. You want to not get locked into a single source.
12/04/2008 2:37 PM
If the flat pattern is as you describe then when rolled will form a conical tank. Is that what you want?
Look at any good, old drafting book and you will find references for sheet metal development.
Also, you should not use the ID or OD when developing the flat pattern of curved sections. You should use the Neutral Axis. An NA of about 40% is a good starting point for most materials.
Travis
Register to Reply 3 comments
Anonymous Poster (1); RVZ717 (1); TVP45 (1)
