I have a stability chamber that is acting very wierd. First the Temperature and RH was not reaching the set point. I opened the control panel and found a blown thermal fuse and 2 contactors that werent holding as strong. I changed the contactors and the thermal fuse and after turning the SC on, the temperature and RH went up to the set point. Temperature is holding but RH is not holding very well, its having a hard time and is fluctuating with 10% of the set range. I am not very familiar with these instrument. I dont know where to go after this. We changed the compressor about 3 months ago but the compressor is making loud noise as well.
