Previous in Forum: Feeding oil from OD to shaft centre   Next in Forum: How to confirm the Pipe Class?
machining time calculation
12/08/2008 1:24 AM
what is the formula for machining time calcutation?
Re: machining time calculation
12/08/2008 1:56 AM
There are too many variables to give you a decent answer with so little information that you have provided.
If you are serious and will be doing a lot of these calculations then I would suggest software such as this:
http://www.cncci.com/products/mepro.htm
If this is only a one-time calculation - you need to provide a lot more information,
12/08/2008 2:04 AM
you can use the CAM progrom to calculate the machining time.
Register to Reply 2 comments
