Previous in Forum: Pumps and Switches   Next in Forum: MV Panel Configuration
CT Dimensioning for Protection Systems
12/10/2008 1:24 PM
why different manufacturers of relay have different formulas for calculating knee point voltage as all are based on same standard?
Re: CT dimensioning for various protection system
12/10/2008 1:53 PM
These are two different issues. The calculations will depend on mechanical and electrical properties of the relay, while standards ensure that they are safe from shock and fire hazards. Any performance requirements in standards will be minimum threshold levels.
Grae
Re: CT Dimensioning for Protection Systems
12/11/2008 8:54 AM
Each manufacturer's design (if not exactly the same) will have different "pull in" and "drop out" voltage values because they will have different (calculated) relationships between the mechanical work (pretravel, stroke & overtravel forces) and the electromagnetic properties of the actuator coil & structural materials.
12/11/2008 12:15 PM
you all are relaing to electomechanical relays......Nowdays there is numeric relays all have simillar working principle
Register to Reply 3 comments
Anonymous Poster (1); gauravgauramu (1); Graebeard (1)
