Previous in Forum: Opinions on Wal-mart-Esq "big box" chains   Next in Forum: Dimensional stability: Plywood vs MDF
8 comments
Biometric Sensors and the Right Epoxy
12/11/2008 8:20 PM
I am trying to build biomimetic sensors, and an important part of this research is matching the thermal characteristics (thermal inertia [mass*specific heat] and thermal conductivity) of the instrument to that of organisms, which is close to water (4180 J/kg k; conductivity =0.6). Has anyone run across anything that might work? This needs to be an epoxy or something else that is rugged but can be molded.
Good Answers: 183
Re: Epoxy with thermal characteristics of water?
12/12/2008 4:44 AM
I have some doubts that you can match mass specific heat but it would be quite easy to match the conductivity (by the way the units you use are?). The dynamic behaviour could may be compensated by a circuit?
Good Answers: 143
12/12/2008 7:20 AM
Have you searched
www.matweb.com
12/12/2008 9:14 AM
Thanks- good lead. The only material listed that is similar to water appears to be BASF Ultramid 8202 PA6 (Dry) [density 0.93 g/cc; specific heat capacity 3.7 J/gK; thermal conductivity 0.26 W/mK- quite a bit lower than water). Has anyone tried to make molds from small quantities (~3x3 cm) of this material?
Good Answers: 183
Re: Biometric Sensors and the Right Epoxy
12/12/2008 12:10 PM
I do not know which type of sensor you want to develop but thinking more about the body thermal behaviour I presume that the only static match with the thermal difusibility (λ/Cp*ρ) in m^2/s will not be sufficient since this way you do not take into consideration the blood convective participation which I presume is not neglectable. If you compare the two materials water and the one you found the second has a difusibility 1/2.15 with respect to water. This is too much to allow a good simulation.
I think that if you have the thermal flow at skin level between a warm/cold body and the skin it could be possible to build a dynamic simulator.
Only a thought.
12/13/2008 9:34 AM
I am CoronaCameraMan,
Seasons Greetings,
Have you considered "dental cement" ? There are no doubt variations of rigid and slightly flexible. These cements must be impervious to water, acids and many other chemicals. They must not contaminate there environment by off-gassing or leaching chemicals. Your base materials may need to be changed to be more compatible with the cements.
Many epoxies are not water proof and will loose there surface bond or disintegrate, including some o-ring epoxies.
Happy Holidays
Good Answers: 94
12/15/2008 4:44 AM
Try contacting Master Bond, they have ranges of epoxies with specific thermal characteristics & an extensive range of medical grade epoxies.
12/15/2008 8:49 AM
You might consider talking to 3M adhesives division.
12/15/2008 10:24 AM
Reynolds Advanced Materials sells a variety of castable epoxy resins:
http://www.reynoldsam.com/index.php?cPath=1295_1298
The manufacturer doesn't provide conductivity data, but working samples can be ordered for ~$25.
Register to Reply 8 comments
Anonymous Poster (3); bhelmuth (1); nick name (2); Nigh (1); TVP45 (1)
