hi;
i am using a wave channel to create and study waves. i have limited my study to shallow water waves where i can easily applly small amplitude wave theory and also because i am not concerned of deep water at the moment. the celerity in shallow water is the square root of g*d ; g = gravity and d = depth.
now since i am using a wave generator paddle i get interference as the wave reflects of the end wall (absorbers cannot absorb all the energy) , so i have had to give an outlet at the end.....and keep the filling pump running to maintain the depth. this is my problem.
i am not sure that the celerity eqaution was meant for such a case......i am in doubt.....can i use the equation?........should i add the flow velocity caused by the pump?......do reply.
thank you.
