Previous in Forum: humming contactor 250v ac   Next in Forum: automatic transfer switch
asking about the impedance of transformator
12/13/2008 5:08 AM
hi...
i'd like to ask about the impedance of transformator (in %). these are the specification of the transformator :
50 kVA, 100 kVA, 150 kVA, 160 kVA, 200 kVA and 250 KVA. all off them have 220/380 volt.
does anybody can help me ??
Re: asking about the impedance of transformator
12/13/2008 6:53 AM
DEAR SIR,
IMPEDENCE OF TRANSFORMER IS BASICALLY THE DESIGNER'S CHOICE. ALL YOUR INTEREST IS TO RESTRICT THE FAULT LEVEL TO PERMISSIBLR LEVELS / POWER SUPPLY AUTHORITIES.
HIGHER THE IMPEDENCE, LOWER THE VOLTAGE REGULATION. BUT LOWER FAULT LEVELS , BUT MORE COPPER TURNS.
LOWER THE IMPEDENCE, HIGHER SHORT CIRCUIT FAULT LEVELS / LESS COPPER REQUIRED.
GENERALLY, MINIMUM VALUE ASKED BY SUPPLY AUTHORITIES ARE 5% IMPEDENCE.
WITHIN IS / IEC TOLERANCES.
Exploring the Science of Electricity
12/14/2008 11:19 PM
HI
% IMPEDENCE = Vsc/Isc
For all these given rating transformer Kva rating is different but voltage is 220/380v,here you will have to do short circuit test of these tranformer,
short the 220voltage side terminal,Apply the voltage at 380v side xmer terminal start from Zero.Also measure the current at 220Voltage side short circuited terminal
Increase the voltage slowly till full load current flows at 220voltage side.
Measured the Short circuit voltage at that time it is your Vsc & Isc you can take as full load current at 220v side.
Each name plate of xmer can give the details of %z also.
any this is the test from that Manufacturer get %Impedence.
regards
SJ
12/15/2008 10:21 AM
It depends on the transformer design, some transformers like Drive Isolation transformers are designed with a higher impedance to reduce distortion caused by VFD drives. You will need to check with the manufacture but 3%-4% is a typical value for impediance of a standard transformer.
Register to Reply 3 comments
Apps Man (1); harry potter (1); SURYAKANT JATANIA (1)
