Previous in Forum: instrument air consumption of a process plant   Next in Forum: can i do bs in instrument and control?????????
Pneumatic Valve and Knocker
12/14/2008 11:24 PM
dear all,
I have a problem regarding air valve. It is used at knockers. Please explain me its working?
United States - Member - US Citizen - Born & Raised Engineering Fields - Control Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Instrumentation Engineering - HVAC/R Simplified Using PLC Controls Engineering Fields - Energy Engineering - HVAC/R Simplified Using PLC Controls
Re: Pneumatic valve and knocker
12/15/2008 6:11 AM
Please review and confirm that this is the application that you are using?
Detailed Product Description
The company Yousung Powder Machine Co., LTD. has manufactured machineries for Pnumatic Conveyance System and Air Knocker is one of peripheral devices for this trasportation system.
In pneumatic conveyance system Air Knocker is a device to solve the problem of powder's sticking effect to Hopper, Silo etc. in transportation process.
- According to the characteristic of powder such sticking problem happens inevitably and then, Air Knocker is a very unique device/machine which works simple but solves the problem efficiently.
- Magnetic Piston equipped in Air Knocker gives shock(6~8 times per a min) to hopper or silo so it makes the flow of materials easy, the principle is knocking the outside of hopper or silo
ie, compressed air blow hit the magnet piston and down part of piston knock the out side of hopper or silo. this function prevent the cohesion and bridge rat hole phenomenon.
-Air Knocker makes you to obtain high efficiency with cheap price.
-Size can be rather smaller than air hammer.
-Per capacity we prepared models of variety.
* Model : YAK-4D ~ 10D
"Memorize the calculations, you look like a fool searching your notes while teaching class"
12/15/2008 6:47 AM
Raj- here's another example:
Your control valve must cycle the air pressure to the knocker to create the pulsation to the hopper. Does this answer your question?
TROUBLE PHENOMENON
BRIDGING
Bridging occurs when materials cling to the wall or compact above the discharge opening of the lower part in the hopper, and the flow of materials in the upper part is interrupted.
RATHOLING
Rat holing occurs when materials flow only above the exit, and form a tube that leaves the hopper filled with "dead" materials, which will not move.
ARCHING
Arching occurs when materials in the lower part of the hopper flow out from the discharge opening, and an arch strong enough to support the entire head load in the hopper is formed
ADHERENCE TO WALL
Clinging materials and also materials easily influenced by the moisture and the temperature adhere to the wall and refuse to flow.
Re: Pneumatic Valve and Knocker
12/15/2008 10:20 AM
Unless I'm misreading the question (and I probably am) I think he's more asking how the air-operated valve works and not so much what a knocker is / does.
Perhaps one of our resident pneumatic experts can better explain it? I would try, but I have to wave my arms around to make sense.
12/15/2008 11:25 PM
You are right. I am asking about the working of this circuit used at knocker.
12/16/2008 7:14 AM
pl let me know the difference between pneumatic vibrator and a knocker. are there mini pneumatic vibrator in the indian market? s.srinivasan
s.srinivasan, falcon engineering works, sivakasi. india
12/16/2008 12:26 PM
The electrically operated solenoid valve is used to switch the air operated valve. This accomplishes two things.
1. It removes the electrically operated valve from what may be a hazardous area.
2. It uses the pneumatically operated valve to pass a higher flow than the small solenoid may be capable of passing.
Have FUN!
TT3
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Register to Reply 6 comments
Anonymous Poster (1); fewindia (1); jcchiefeng (2); RAJ KUMAR (1); Turbotroll3 (1)
