Previous in Forum: Carbon Nanotubes   Next in Forum: On-line Free Chlorine Analyzer Sea Water ATEX
11 comments
Manufacturing Fasteners: How to Get Moulds and Process?
10/22/2006 5:43 AM
I am interested in manufacturing nuts, washers, bolts, nails, screws, locks, levers and handles, I would like to know information about processing to form these products and how I could go about to get moulds.
Thank you in advance.
Also posted in: also posted in Manufacturing
Re: nuts, washers, bolts, nails, screws, locks, levers and handles manufacturing
10/22/2006 9:23 AM
Sorry this isn't much help, but your title reminded me of a newspaper headline (probably from urban myth), about a lunatic who assaulted the workers in a laundry before fleeing:
NUT SCREWS WASHERS and BOLTS.
Good Answers: 120
10/22/2006 10:52 PM
Cheap nuts and bolts are pressed in high speed machines. precision ones are cut on autofeed lathe type setups.
Cost of entry is high, established people have old fully paid for machines to do this. New people have very costly high speed ones for the same task. It is a low end commodity...why do it?
Per Ardua Ad Astra
Good Answers: 75
Re: Manufacturing Fasteners: How to Get Moulds and Process?
10/23/2006 2:42 AM
Didn't you ask this question a couple of days ago or is everybody trying to get into the business?
Asking a question as broad as yours is like asking how long is a piece of string. The answer is it can vary enormously depending on what they are used for. At one end of the market you have hand made items built to fine tolerances and at the other end of the market you have cheap mass produced low tolerance items.
I don't think you have a clear understanding of what goes on. Just because two bolts look alike doesn't mean they are the same. Many engineering disasters have been caused by people thinking identical looking items are interchangeable.
If you are going to go into it without understanding what the end product is used for and it requirements and just produce a product that you think is correct then you will probably end up causing another engineering disaster.
I will give you and example. During the maintenance of an aircraft a maintenance engineer found a faulty bolt that held the wind shield. To be safe he replace all the bolts with new ones that appeared to be identical. The result was that the were not identical and as the aircraft passed through about 25,000 feet they failed and the windscreen blew out taking the pilot with it. Fortunately for all on board the flight engineer managed to grab the pilots legs before he was completely sucked out the window and the co-pilot managed to land the aircraft. They came very close to him going out the window and taking the tail plane off in which case everybody on board would have been killed.
Do you get the picture now?
10/23/2006 3:12 AM
The process for Nuts,bolts are different with nail,washers and level handles.My manufacture can offer various moulds for forging,pressing and handles.There are CNC,EDM machine in my manufacture.Hot stampling moulds,die-casting moulds and cold press mould available at present.If you have any enquiry about them,please contact me.
Hope i can help you more.
william.bei
10/23/2006 3:16 AM
We are machine tool dealer and we export these machines. If you need more information, please contact with me. henryzhang1@hotmail.com
08/25/2009 10:54 AM
plz send me all detail for fastner making machinary ,
cost of machine
market of fastner
10/23/2006 11:04 AM
The high end of Screw manufacturing requires: Hot forming, cold heading, metalurgical knowledge, heat treating, surface finishing, plating, microstructure analysis and a host of other information. At the other end of the spectrum are high speed screw machines and hot headers which produce product at high rates of speed with excellent process capability. There are no molds as such for most screws, they are peoduced by other means. It seems to me that you need to do a lot more research before committing to this venture.
Good Luck
It is better to light a lamp than curse the darkness
Good Answers: 120
10/23/2006 11:56 AM
I suggest he specialize in left hand flat washers(non locking), Niches like this have fewer competitors.
Per Ardua Ad Astra
Good Answers: 75
10/23/2006 12:16 PM
Especially the metric ones, they're really hard to get.
12/14/2006 9:07 PM
I can give the TECHNOLOGY for "COMPOSITE COATING " with PHOSPHATING for HIGH TENSILE FASTNERS for large FASTNERS also please contact TEL NO91-20-24532278 CELL No919890948731 MAIL:anantr_@rediffmail.com
REGARDS
RANADE
01/09/2013 7:11 AM
Super Engineers is the best leading manufacturing company. They manufactures fastners, nuts, bolts , pins, screws , washers and many more. For more information visit the site.
fastokfasteners.com
Register to Reply 11 comments
andy123 (1); Anonymous Poster (2); aurizon (2); dealer88 (1); JohnDG (1); masu (2); Sixsigmaengineer (1); user-deleted-1114 (1)
