Previous in Forum: Axle Bearings and Seals in Saltwater   Next in Forum: New Motor Technology
One Dimensional or Two-dimensional Heat Conduction
10/23/2006 7:38 AM
I want to design an iron. Is it necessary to take the thickness of plate in heat loss calculation? I want to neglect thickness but I am not sure. Surface area of base plate is large relative to its thickness and in heat transfer books thickness is negligible. Thanks for advice...
Re: One Dimensional or Two-dimensional Heat Conduction
10/24/2006 12:10 AM
if it's steady state convection will be equal to conduction. in that case you can ignore thickness and just use surface area for heat loss calculation.
kaiser
10/24/2006 10:26 AM
Actually you have 2D analysis since you should be interested in evenly warmed surface and you will need to add energy at some points.
If you are not looking for energy accumulation (time dependent) thickness is neglible, if inertial effects are important, then mass (and thus thicknes) need to go into your analysis
Register to Reply 2 comments
