Previous in Forum: Understanding Earthing Systems   Next in Forum: Transformer Voltages
480 volt motor
12/17/2008 9:05 AM
Does antone know where I might find a used motor with the following nameplate data.
400 hp
505UP frame
1775 rpm
480 volt
455 FLA
Thanks Darold
Re: 480 volt motor
12/26/2008 2:49 AM
Try a reputed manufacture, shop or at auction.
BNDas
Re: 480 volt motor
02/01/2009 9:12 AM
First you should log in here so everyone knows where you are located to be able to suit you better Second you should try to obtain a motor frame croos reference chart or book Third is that particular motor frame designation NEMA, IEC, or Metric , I ask because I had a Shultz DC motor die on me last month witha frame designation of 103 (which didn't show up on any chart I have) I was told it was a discontinued Metric frame style But if you are in the US (or can order from here ) there is a web site called www.wireandplastic.com and they have 4-6 different warehouses across the US full uf new, used, refubished equipment and motors. I use them all the time when I loose an older setup for my plant. And what is wrong with you motor that it can't be rebuilt??? I have seen some real bad stuff happen to all sorts of motors and as long as it can be disassembled it should be repairable Hope this helps
We cannot solve today's problems with the same level of thinking the created them---Albert Einstein
