Previous in Forum: I-Beam Strength   Next in Forum: welding
clarification on I-Beams
12/17/2008 10:51 PM
Dear friends,
I need to design a container to carry 14 tons of one assembly looks like a round disc(size: Dia 2500x 300 thk) . For that i was advised to use I-beams at bottom as a "Ribs" which is taking care of entire load . the entire round disc to be covered by thin sheets. From top it has tobe lifted by 4 to 6 lifting lugs. For the above, i request you to guide me to decide the size of the steel I-beams and its construction details.
Regards,
M.Rajkumar
Re: clarification on I-Beams
12/18/2008 8:45 AM
I'd start by deciding how many lifting points and how the load will be supported on the platform. Check if the load is evenly distributed or if there are areas of more localized loads, because you'll need to reinforce there.
So, start design by placing beams connecting the lifting points and the most loaded areas. Proceed this way ending up with a frame of beams. Dimension beams individually or in the assembly as you'd do anyway.
Need an outter rim connecting them? Are you thinking about curved beams to fit the round shape? I'd think twice about that. Straight and square things are much easier to do. And can be assembled from off the shelf material.
You mentioned your assembly is round, but, do your platform needs to be round? Maybe a square one with liftings in the corners could do just fine.
I agree I beams would do great, at least with the mentioned initial approach.
Humm... suspicious you are...
Reply to Forum Thread
