Previous in Forum: Drilling Conic Holes   Next in Forum: ANSI, ASME and CATIA V4
What's New in ASME VIII Div. 2 Edition 2007?
12/19/2008 1:17 AM
what is the basis of new code VIII-2 ED.2007?
What are the major changes and what are the basis to change?
How i can find the evolution of new code? means how does it affects existing Performance of pressure vessels. w.r.t Cost, weight?
Paresh B. Gujarati
Re: What's New in ASME VIII Div. 2 Edition 2007?
12/19/2008 10:03 AM
It sounds like you are looking for too much detail that could successfully be explained within this forum.
I suggest you get a hold of a couple of papers already written, specifically:
  1. Criteria of the ASME boiler and pressure vessel code for design by analysis in Sections III and VIII, Division 2; ASME c1969
  2. Modernization of Pressure Vessel Design Codes ASME Section VIII, Division 2, 2007 Edition
And do a Google search which should bring up items such as:
http://www.paulin.com/Library/Fatigue_Info/Hinnant_Comments_on_Div_2_Rewrite_SSM.pdf
You might be interested in: Bar Code Scanners, Bar Code Cards, Bar Code Software
