Previous in Forum: Air / Fuel Ratio in Coal-Fired Boiler   Next in Forum: JIC Dimensions
hogger system
12/19/2008 9:50 AM
what is the hogger system in condensing cum extraction steam turbine
Re: hogger system
12/19/2008 10:39 AM
The hogger refers to a steam jet or vacuum pump of high capacity, usually with low efficency. This would be like a steam air ejector exhausting straight to the atmosphere using up heat and condenste with no return.
The purpose is to get the vacuum up initially. They are usually secured after 20 inches or so of vacuum.
If you fail to follow through, you will fail.
Reply to Forum Thread
