Hi there..
In the irrigation system the size of the pump suction pipe from the water tanks is 300mm, the discharge is the same size. Now after the disharge pipe 300 mm, connects to the filters suction that is bigger size 400mm and discharge after the filters that is 400mm as well.
My question is : the size of the pipe suction for the filters should be bigger of the discharge pipe size from the irigation pums?? is the above system going to work or all the pipes should the same size or pump suction/discharge should bigger size than the suction pipe size for the filters?
Thank you!!
