Is a consistant form and method of building and structure frame/body reinforcing a wanted change in the Construction Industry?
I've built, designed, and reviewed/inspected buildings for over 30 years, and the only thing ever asked of me has been Consistancy!!
When I spec out a wood frame and wood truss on continuous foundation house, for example, I spend more time trying to figure out all the post bases, caps, wind and seismic twist and strap-ties, let-in and shear bracings, midwall blocking, floor and roof cross-frame bridging, diaphragms, etc; than any part of the designing/estimating processes!!
Can anyone confirm that continuous reinforcing will reduce designing and estimating time, hazardous construction practices for the skilled laborforce, and materials/fasteners?
Outside of Continuous Connector-Reinforcing Structural Strap-Nets, I am not aware of any other type of continuous reinforcing systems. You can find these systems at website: Tor-Eggs-Tor Design Solutions, or via link at: http://www.dubephnx@tor-eggs-torclosed-nets.org.
These three-phase structural reinforcing systems resist initial impacts, add extra load distribution tributaries that help reduce the initial impact loads, and provide a complete tension-resistance frame movement containment feature that looks like it could improve the amounts of wind, seismic, etc; forces the accessorized structure/frame can resist.
Cost effective at the construction phase, cost effective in tornados, hurricanes, earthquakes, etc; cost effective for the environment, cost effective for the home buyer, cost effective for the Engineer/Architect/Builder, cost effective for Insurers and Investors, and cost effective for the Steel Reinforcing Products Manufacturers!!
Can you review these systems and critique them? (This way you don't have to compromise your Codes of Ethics) Thanks up front;
Randy Dube, Innovator and Developer of Continuous Connector-Reinforcing Structural Strap-Nets and Extensions.
