You need a phase converter. You can get or make one with a larger 3 phase motor and capacitors in what is called a "Rotary Phase Converter" or RPC, or you can buy a Static Phase Converter that does it electronically. Many VFDs (Variable Frequency Drive) can act as static phase converters as well, but may be a lot more expensive because they are ntended to do more. It all depends on the HP (kW) load of your A/C unit.
