Previous in Forum: PLC Training   Next in Forum: AVR GENERATOR BOARD KEEPS BLOWING
Motor connection STAR or DELTA ?
12/27/2008 4:05 AM
Why HT motor connected in STAR and LT motor connected in DELTA connection ?
Good Answers: 804
Re: Motor connection STAR or DELTA ?
12/27/2008 4:41 PM
Because that is the way the motors were made.
02/25/2009 9:13 PM
to reduce the insulation .in star curreent will be same ( IL and I phase) but voltage will be less so we need less insulation in star winding.
12/27/2008 5:21 PM
guest; the windings determine connection, example coils wound for 230 volt ac could be hooked up for 230 volt delta, or 400 volt star/wye connection, making it a dual voltage motor or if it is a large HP motor it could be hooked up for reduced voltage starting. perry
12/29/2008 2:00 AM
guest; i may not been real clear on my answer to your question? in the USA most 3 phase motors are wound with dual windings, for 230 volt or 460 volt depending upon the connections the basic winding is star/wye numbered phases 7,8,9, the other 3 windings are numbered 1&4, 2&5,3&6, tie 4,5,6 together, connect 1&7, 2&8, 3&9, 3 phase 230 volt star connected, for 460 volt. tie 4to7,5to8,6to9, for a star/wye connected 460 volt 3 phase motor. many countries use a 3 winding motor with 6 connections for delta 230 volt or star/wye connected 380 volt 3 phase 50 HZ Perry
05/05/2010 12:27 AM
as we know in star connection I phase = I line and in delta V phase = V line. so , in HT motors when we connect in delta, I line = 1.732 * I phase. so i will draw high current as a result , it will reduce the insulation life of the winging. thats why we connect in star. and this will not come for the LT motors.
Anonymous Poster (2); JRaef (1); perry (2)
