Any surveyors out there? Here's my question.
With respect to the township and range system.
Referring to a parcel's legal description which was generated, say, over 50 years ago, a surveyor is attempting to plot out the parcel's boundary lines and post landmarks at the four corners. Given the movement of magnetic north in the intervening years since the original survey, how is the surveyor able to follow the bearings given in the earlier survey? If I wanted to trace out the boundaries using a compass and chain will I be able to do so? How?
Finally, what is a Cadastrial survey, how is it accomplished, how does it differ from township and range?
Thanks you.
