Previous in Forum: vacutainer requirement in order to meet GMP compliance   Next in Forum: NRV Testing
Diesel Fuel Injector Nozzles
12/30/2008 6:05 AM
HI ! what is the effect of different geometrical dimensional on performance of nozzle although they have same nomenclature? i mean there is diesel injector BOSCH nozzle having nomenclature DN 6S 197 but there is observed difference in dimension or u can say tolerance of fuel feed hole between the nozzle made in france and the nozzle made in INDIA . more over indian nozzle observed to have increase failure rate ! can any body plz let me know how big companies ensure quality control ? is there any international standard ? do these nozzles with same nomenclature should have different geometry dimension ? what are different test which can reveal and prove that geometry difference will affect performance ? help and time is appreciated
Good Answers: 243
Re: Diesel Fuel Injector Nozzles
12/30/2008 7:05 PM
ATIF, there is a hell of a lot more to a fuel injector and it s manufacture than the hole size. Starting with material. manufacturing process. finishing process. other processes.
the bosch plant in france has created a system to make these so that they perform as expected.
you get what you pay for.
milo
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
12/30/2008 11:35 PM
i agree with Milo even change in hole dia by two thousandths of an inch will alter the combustion process,fuel consumption and emissions,apart from you need to know that combustion chamber configuration has to be looked at when you discuss the injectors and nozzles its an exiting world iterating injector nozzle development
crm
Run silent run deep
12/31/2008 5:56 AM
hi crm ! can u plz let me know any standard , control document or any other relevant data which could be used to support your arguement infact our supplier saya there is no problem with dimensional difference so we need to convince him giving credible proofs ! your help is appreciated
12/31/2008 7:30 AM
dear friend i shall send it i need to go back to Bosh and Indian institute of science where i was a team member for developing emission compliance engines.Give me few days as on to day i am retired from Caterpillar and working as a services technical advicer for small company.hope you will bare with me you can check diesel net,in the mean time for your urgent requirement diesel net is an excellent resource center.for detailed information you need to have access as for as i know fuel injector system is Tailor made for each family of engine and recommended to call on engine manufacturer if you are making any change in Fuel injector and system.
regards
crm
12/31/2008 11:02 AM
Bosch provides that kind of information ,rates, etc.to any, i mean, every official Bosch workshop.Commonly at less, they have the information for any pump even when the engine and its pump is unknown for them.I should go to any other Bosch workshop or even complain in headquarters to get out of doubts.Good luck.BY the way..Happy new year for everybody!!!
07/06/2010 1:01 PM
do you produce the nozzle and plunjer zexel and bosch orijinal injector pump of komatsu...?
Register to Reply 6 comments
Anonymous Poster (2); ATIF NAVEED (1); crm (1); ferquiza (1); Milo (1)
You might be interested in: Nozzles, Fueling Nozzles and Receptacles, Air Blow Guns
