Previous in Forum: How do you plan your 2009? How you support these dos? Can you suggest a name?   Next in Forum: Top Flight Technology,.Co.LTD
Break my Frame!! I Challenge you!!
12/31/2008 2:14 PM
I have developed the world's strongest building/structure frame reinforcing systems in history!! Called Structural Strap-Nets, they blow away any competitive reinforced frame systems anywhere!!
Patented Isolated Reinforcing Connectors? Toss'm!
Post-Tensioning of Concrete Slabs? Bury'm!
Geodisic Dome Tension Frames? Sink'm!
3-in-1 Continuous Connector-Reinforcing Structural Strap-Nets install to open-space, closed-space, in-fill, and solid-wall frames, and add 1) Impact Force Resistance Strengths, 2) Absorbed Loads Reductions, and 3) Accessorized Frame/Body Movement and Separation Resistance!!
Your challenge, if you choose to take it on, is to put up your favorite structural frame system up against the same structure frame with Structural Strap-Nets replacing the reinforcing methods of your frame, and figure out the differences in Lateral, Uplift, Rotational, and Overturning Resistance Strengths and Performabilities. I don't care if you use Calculations, Scientific Methodology, or Physical Tests.
You can find the basic instructions, assembly methods, and property values of Structural Strap-Nets at the website: Tor-Eggs-Tor Design Solutions.com, link: http://www.dubephnx@tor-eggs-torclosed-nets.org
Post your findings on this Forum Thread, Have Fun, Happy New Year;
Randy Dube, Innovator and Developer of Continuous Reinforcing Technologies.
PS: I have the answers, be honest.
Good Answers: 183
Re: Break my Frame!! I Challenge you!!
01/01/2009 6:22 AM
Since you boast everywhere with your product I wanted to have a look at this marvel.
But when I used the link I got the answer that it cannot be found!
Are you sure that the product exists ? or is it only a dream?
01/01/2009 6:45 AM
Try the Tor-Eggs-Tor Design Solutions.com search engine method. These systems are a new technology, that are illustrated with existing products, to show the differences of what the new technology replaces/assists. The Products will be by others (whoever licenses the copyrights of the new technology, of which I own currently.).
It was a dream, now it is a reality!! FYI: Several CR4 Bloggers have viewed the website, and one is saying that you have to use the www. address. The link is being blocked by CR4, I believe, probably because New Technology Announcements and improvement equals "spamming"? I submitted this challenge on the New Technologies and Research Forum, but it ended up here in the Commercial Forum. (SHSHSH; I think I'm being watched; wouldn't want someone to live through a disaster, these "security watchdogs" keep making sure of.)
Hope you get to take the challenge, Nick-Name!! The challenge lets you try these out for yourself, without endangering anyone!
Randy Dube
Good Answers: 183
01/01/2009 2:57 PM
1- Since you make the promotion of your product you have to be on the commercial side.
2-I had a look thanks to google
3- It is on my modest opinion asymmetric and will not offer same properties depending on loading directions
4- If you do not like the way CR4 works nobody obliges you to be here.
5- I do not see any revolutionary things it is a quite current connection as in other fields of technique
6- If the connection is too stiff it could direct destruction somewhere else so that the whole has to be harmonized with type and magnitude of loading
7- Some words in your advertising are not written the correct way. I would suggest you make a dictionary check and correct them.
8- I wanted to have a look at the "physics" and "proofs" but it was impossible to open the files so that I assume they are not yet available. Do you have any tests done ?
Good luck but I am personally skeptical.
United States - Member - New Member Technical Fields - Technical Writing - New Member Popular Science - Weaponology - Organizer Hobbies - Target Shooting - New Member Engineering Fields - Nuclear Engineering - New Member
01/02/2009 8:16 AM
This post is an advertisement, and has been moved to the Commercial Space forum by CR4 Admin.
01/05/2009 8:06 AM
is something wrong with the link? I cannt access to it.
is it a marvel? post a picture here.
cnpower (1); dubephnx (1); nick name (2); Steve Melito (1)
You might be interested in: Frame Grabbers, Playfield Equipment, Takeup Bearings
