Previous in Forum: Drop in mA .   Next in Forum: about MODICON TSX 3722
9 comments
Steam Line Pressure tap seal pot installation
01/01/2009 4:58 PM
When installing a seal pot for a main steam pressure transmitter. Were should the seal pot be located in respect to the main steam line? Thank You
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
Re: Steam Line Pressure tap seal pot installation
01/01/2009 11:00 PM
On top of the pipe with an isolation syphine to prevent "live" steam from hitting the transmitter.
Mike
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
01/02/2009 6:42 AM
The setup is tap off the top of the steam line. Were should the seal pot be installed ?
Along side the steam line or above or below the steam line? And were should the
transmitter be located? Thank You
Good Answers: 68
01/02/2009 12:00 AM
Hello Guest,
you seem to have a pretty good answer from the expert "Boilerguy". But here is a few other choices:
http://uk.search.yahoo.com/search;_ylt=A1f4cfP3nV1JkT4B7jJLBQx.?p=installing+a+seal+pot+for+a+main+steam+pressure+transmitter&y=Search&fr=yfp-t-501&ei=UTF-8&rd=r1
Take care and have a great new year................
01/02/2009 11:42 PM
Great references. Thanks for sharing.
Mike
Good Answers: 68
01/05/2009 10:11 PM
Hello mike,
My pleasure my friend! Really your name says it all!
Take care and a great new year.................
11/19/2009 9:14 PM
hi all!!
I would like to help me with a problem I'm having problems with a boiler level sensor (differential pressure)
when the boiler delivers less than 4000 kg / h of steam sensor readings are correct
when given a little over 4000kg / h sensor readings are an inch above and when delivery 11000 Kg / h sensor readings are about 3 inches above
reviewing the plans, I realized that the reference HP (bottom of the boiler) the sensor is connected in the wrong place next to the right place but do not think this is the real problem I think the real problem is that I did not put a " seal pot" in the reference leg LP (top of the boiler) this may be the cause of my problems?
influence too much the "seal pot?
which is exactly what happens inside the boiler?
to deliver steam to a large amount this makes the pressure at the top of the boiler to drop so that readings vary according to the flow of steam?
in a few days the boiler stopped to make the necessary changes and make sure I get it right this time
thanks for any help best regards
excuse my English I understand it ............. but my writing is disastrous
06/30/2013 5:47 AM
Dear All
what about the orientation of the seal pot any preference.
Regards
08/03/2013 11:55 PM
Dear All
for the seal pot it is necessary to use vent plug or blind plug.
any advise pleaseee.
Regards
Good Answers: 176
08/04/2013 2:12 PM
I've only seen plugs, like the hex plug below used for sealing the top port after filling the pot and impulse piping.
Although a vent valve would allow an air purge on start-up, I'd have to think about a safe way to manage it. I'm sure the style with a vent tube or barb (on the right, below) would be essential for conducting the vented air/fluid/steam safely.
Those kinds of high pressure vent valves are routinely used on DP transmitters, I can't see a down side. Might have to use a pressure rated reducer bushing.
Maybe a steamboiler guy has another opinion . . .
Anonymous Poster (3); babybear (2); gabrielmuñoz (1); Iris (1); miketheboilerguy (2)
