Previous in Forum: Steam Turbine Leak Testing   Next in Forum: fuel cells
FRP Panels for Weir Plates and Baffles for an Air Lift Sewage System
01/02/2009 9:14 AM
Hi Folks,
I hope someone has a quick and easy answer for me. In the North East (USA), are there any manufactures that make Fiber glass Reinforced panels(FRP) that could be used in a sewage treatment environment?
The manufacture would need to meet specs required by Pennsylvania's Dept of Conservation and Natural Resources.
The job I am pricing out will require some : weir plates, Baffles and appx 35' x3'-6" x1 1/2" grate walk way (with FRP anchors brackets)
Thanks in advance for your response
Respectfully,
Terry
Pathfinder Tags: fiber glass FRP sewage treatment
Good Answers: 101
Re: FRP Panels for Weir Plates and Baffles for an Air Lift Sewage System
01/02/2009 10:17 AM
Any manufacturer of FRP tanks can fabricate them as long as they are provided with the correct specifications.
You might be interested in: Sewage Pumps, Grinder Pumps
