Dear Sirs, In an induction steel melting core less furnace of 9Tons capacity near Hyderabad (India) ,the sponge iron fines of about 70%Fe is used along with Shredded scraps I.S.R.I 211(imported). The Al2O3 in the sponge iron was found around 6% to 7.5 and sulphur around 0.07 %depending on the sources of supply .
The slag is viscous and there is about 25-35%Fe in the slag which is removed manually from the open furnace.The power consumption is about 750KWH/T.We have tried 0.5 Kg of silicon carbide mixed with sponge iron fines in one heat and the Fe in slag is reduced to around 2% .
When silicon carbide was added along with steel scraps Fe in slag increased by 2%. We get about 7.5 tons to 8.3 tons of steel only from one heat.
Can any body give me some tips to
a)Reduce power consumption ?
b) To reduce Fe loss in slag
c)To make slag fuild so that slag metal separation shall be easier.
d)I am yet to get a supplier for calcium silicide at Hyderabad.Can any body suggest a reliable supplier and tell me the effect of calcium silicide if added.
There is not much scope to cover the furnace top as charging and removal of slag from furnace is to be carried out.
Regards,
PGPanikkar
pgpanikkar@rediffmail.com
