Previous in Forum: How does an AC solenoid valve works???   Next in Forum: DCS/ESD
location of DP level transmitter
01/05/2009 10:41 PM
Could someone can advise me the location of DP level transmitter? It should be at lower nozzle elevation? Can I mount the LT far below the lower nozzle? Where is best location?
Thank
Nanky
South Africa - Member -
Good Answers: 12
Re: location of DP level transmitter
01/06/2009 12:44 AM
Hi there,
Ideally you would want to mount the transmitter at the lower level elevation. If this is not possible you can mount it below this point - the important thing to bear in mind is the height as this is part of the equation that you use to get the level. i.e. pressure = height x density x gravity. So by this you will have to take the extra height into consideration.
I would also consider a wet leg installation - depending on your process medium and mechanical setup.
Regards,
Craig
01/08/2009 12:09 AM
thank for your information. I forget to let you know that I am using wet reference leg DP level transmitter for closed tank. So if I mount the transmitter 2-3m below the lower level elevation how does it affact to level in the reference legs when temperature change?. Thank you.
India - Member - ADIL MOULA Engineering Fields - Instrumentation Engineering - Adil Moula
01/09/2009 10:04 AM
if both legs comes down with same length than the head gets balance provided hp leg has to be filled with liquid,what is filled on wet leg ,generally HP tapping is near to the nozzle .it depend on the access you need for maintenance .
Good Answers: 12
01/12/2009 1:43 AM
Hi there,
I would only worry about the temperature change if your ambient temperature is a huge difference from the medium inside the tank. Obviously the temperature difference will affect the density - but the error is not that big, especially if your tank is quite large and you do not require 100% accuracy.
If you were measuring on a steam drum level for example then I would do things a bit differently as you need to compensate for this temperature change as well as the pressure fluctuations within the drum.
I have posted a solution for this in this forum - just have a look to see if the solution applies to what you want to do.
Regards
Craig
02/03/2009 12:54 PM
hello
You can fill the wet leg with water (or mixed with glycerine). It doesn't matter where your dp is locating (i mean under the hp - receipt or at the same level). you can take 4mA(calibrate) with filled the wet leg. So the dp has to be at an accessible point.
Panathinaikos
Anonymous Poster (1); craigza (2); find2am (1); HELLINAS (1)
