Previous in Forum: mechanical engineering final year student   Next in Forum: How to Test Air Compressors
Steam Turbine Questions
01/07/2009 1:26 AM
Difference between controlled & uncontrolled extraction regarding steam turbine.
what is the best method of controlling vacuum in the steam turbine with reason
According to thermal efficiency which type of steam turbine is best with reason.
Re: Steam Turbine Questions
01/08/2009 8:45 AM
1. Controlled extraction is accomplished by having a separate set of control valves downstream of the inlet control valves backing up pressure in one section of the turbine.
Uncontrolled extraction is taking a flow from a stage in the turbine to a feed heater etc. that varies with load.
One set of control valves can only control one function, speed, load or flow.
2.The best vacuum is maintained by controlling leakage of air into the system. Most other things like cooling water temp etc. you don't have much control over.
3. There are no purely reaction or impulse turbines, so I guess that is still a question.
If you fail to follow through, you will fail.
