Previous in Forum: How to Test Air Compressors   Next in Forum: Calculation for a Boiler Feed Pump
12 comments
Removing Snow and Ice from Bus Rooftops
01/07/2009 8:09 AM
It is snowing and icing. I am in transportation business and I need to come out a system to remove the snow and ice from the rooftop of bus before it departs for services. Any suggestion will be appreciated. The snow/ice removal must be quick. Imagine a system must remove snow/ice for several hundreds buses in each depot and each bus only allows several minutes to remove the snow/ice. Build a huge shed costs too much money to justify for remove the snow only less than 10 times a year.
Bus is approx 9' wide and 11' high and 40 ft long.
Good Answers: 38
Re: Removing Snow and Ice from Bus Rooftops
01/07/2009 8:51 AM
We use a system of 2 upright beams with a hoist suspended on the cross beam. Our trucks or trailers will move into place through a series of cones to the plow suspended from the hoist. It is held in position by two guide rails to keep it level and from swinging. The operator lowers the plow until the chain just starts to become slack. Then he raises it just a bit to keep excess weight off the roofs. The vehicle slowly moves forward until it clears the plow. Then we have a little bobcat with a bucket on the front to push the built up snow out of the way and pile it up off to the side. Works great, but you need to have a reliable person operating the plow/hoist. The plow is a V to push the snow to the sides rather than one side or the other.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 38
01/07/2009 11:04 AM
By the way. The wiper on the plow is made of rigid rubber, not steel.
01/07/2009 11:25 AM
I concur with charsley99 Use an I-beam stand with a plow hanging down. Being Buses and roof damage would not be good. I would look at using a rubber squeegee like use in a car wash to clean off the snow with an added air blower system like use in the car wash to blow off the snow and water. Come summer add spray nozzles and wash and dry the buses on there way out
It can be all self controlled with sensor and limit switches. There are a number of sensor system available, Light bean, micro switch , pressure pads. That will turn the system on and off. The cost is how elaborate you want to get. I would think the over the top roller to start air blowers if used would work well. The amount of space you have to work with, local government and DEQ laws.
I would keep it simple. With an I-beam stanchion, rubber scrapers formed in the general shape of the bus roof. With and air blower on one or both sides to help move the snow off and leave the bus in a dryer state. Do not make the rubber to hard as it will damage the paint and cut rivets and catch on sharps. I think there wil alway be a thin layer of ice/ snow on top.
As far as the snow that has been removed you are on your own there.
Everett w.
01/07/2009 12:31 PM
Driving fast doesn't work for you? That usually takes the snow off for me.
Good Answers: 15
01/07/2009 12:40 PM
We could be ticketed for that in our state. Safety issues.
But people still do it.
downhill slide to 112 (damn memor.)
Good Answers: 266
01/07/2009 12:53 PM
High pressure shower and blower combo.
01/07/2009 3:26 PM
put a heater in each bus and plug them in at night
Good Answers: 19
01/07/2009 5:58 PM
Run the bus through the bus washer? Water will melt off the snow if it is only 10 time per year.
I also like the hi-pressure, hi-velocity blower idea suggested earlier. Support an air stripper with 50-60 mph blast of air at the top of the bus and blow off the snow.
01/21/2009 8:29 PM
Sir,
Call Bill Candeletti at Durasweep, 904-687-5658 or you can email him at billc@durasweep.com. Durasweep is commericial vehicle rooftop snow removal machine which uses a street sweeper type brush that spins at 200 rpm. The brush is made for all types of roof configuration including buses, The durasweep also sprays a deicing agent both before and after the brush.. Call them..
01/21/2009 8:42 PM
Just wanted to make sure you got my post about contacting Durasweep. www.durasweep.com. or billc@durasweep.com.. Machine works awsome.
10/09/2009 6:23 AM
Check out the Durasweeper,, www.durasweeper.com its the only machine out there that can clean a bus rooftop since it uses a brush...my company bought two last year and they work very well..............
02/13/2012 11:37 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Anonymous Poster (2); Billc121 (1); charsley99 (2); ddk (1); everett w. (1); healybj8 (1); ozzb (1); Ried (1); roofrake (1); tank farm guru (1)
