Previous in Forum: Fuel Tank Calibration   Next in Forum: trolli
ASTM A36 pipe
10/27/2006 9:51 AM
Dear Sirs:
I am searching for providers or manufactures for rolled and welded pipes, based on the specification as follows:
Material: ASTM A36 or A139 (Grade B)
Item a) OD 18" , Wall 5/8" , Qty 33 pcs L=20'
Item b) OD 18" , Wall 1/2" , Qty 33 pcs L=20'
Electrical resistance welding : ERW
Interior coating Epoxy with bitumen base
Exterior coating Epoxy with zinc base
The pipe will be used for a penstock prolongation in existing Hydroelectric Plant.
The maximun static pressure is about 810 psi.
Hydrostatic test will be need.
I will appreciate any comment.
Thanks in advance
Eng. Nelson García G.
ngg@entelnet.bo
The Feature Creep
Re: ASTM A36 pipe
10/27/2006 3:39 PM
We can check out Globalspec's area for pipes here; http://process-equipment.globalspec.com/SpecSearch/Suppliers/Processing_Equipment/Pipe_Tubing_Hose_Fittings_Accessories/Pipe
I'm sure that people here can suggest a vendor that they like though.
"The future is here. It's just not widely distributed yet." -William Gibson
Re: ASTM A36 pipe
10/28/2006 10:21 AM
Dear colleague:
Actually we found two industries working in manufacturing custom pipes like we need.
We will try to get contact with them.
Thank you for linking us to the correct site.
GGI
Re: ASTM A36 pipe
10/30/2006 10:26 AM
try Northwest Pipe Company Washington WV phone-304/863-3316 fax 304/863-6984
Register to Reply 3 comments
BRodda (1); ggi (1); roadapple (1)
You might be interested in: Epoxy Adhesives, Panel PCs, Tablet PCs
