Previous in Forum: Saturday entertainment!   Next in Forum: Emergency Preparedness
31 comments
Mass in motion
01/10/2009 12:30 PM
Greetings CR4 Users,
My question is:
Would a mass (say a truck (40 metric tons)) traveling at 80 Kilometers an Hour produce more, less or equal force to the road as a truck traveling 60 KmH ?
If more or less and leaving out or using a standard aerodynamics how would that be mathmaticly proven ?
I hope this question is not to vague and thanks for any replies.
Re: Mass in motion
01/10/2009 12:35 PM
good question.are you suggesting a bit of lift due to the forward thrust of the vehicle?or perhaps some downward drag from same due to poor aerodynamics?certainly one to ponder.
CARPE CRUSTULORUM!
Good Answers: 88
Re: Mass in motion
01/10/2009 12:45 PM
Are you interested in the impact of different speeds on road wear? Fuel economy? What is the motivation for your question?
Re: Mass in motion
01/10/2009 12:52 PM
The question deals with driving a truck across a bridge here in Germany.
If they find a bridge (on the highway) to be damaged in any way they will slow the traffic down while crossing it. A trucks normal speed limit is 90 KmH gets reduced to 60 Kmh. Is there any reason behind this ?
Would it not be wiser to get the weight off the bridge as fast as possible ?
Good Answers: 103
Re: Mass in motion
01/10/2009 12:54 PM
Draw the vector diagram at the tyres and you get the answer.
The truck is working against
a) The wind resistance depends on the velocity (you need flow modelling/ wind tunnel experiment)
b) the tyre friction with road (depends on the weight also)
c) other losses - say due to grip and likelihood of skiddings at various speed.
mathematics is tough for me.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: Mass in motion
01/10/2009 1:14 PM
The truck weighs exactly the same at 80km as it does at 60km. However, variations in the road surface will cause the faster truck to exert more force to the road.
Example, picture a truck going at 60km and hitting a speed-bump. The truck will be deflected upwards, then "fall" back to the road, like dropping a weight. Picture then, same truck hitting same speed-bump at 80km. It will be deflected higher, and then fall father, so, dropping the same weight further, exerting more "force" on the road.
So, it makes perfect sense that they do this.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Re: Mass in motion
01/10/2009 1:38 PM
Thank you for all the replys,
So, if there is no apparent damage to the road surface and any defect would be structural then there would be no reason to slow down the traffic, right ?
Im kinda looking for a safety net if i were to get caught above the speed limit in such a situation.
Good Answers: 73
Re: Mass in motion
01/10/2009 1:47 PM
"Im kinda looking for a safety net if i were to get caught above the speed limit in such a situation."
You now have only an illusion of a safety net. When you are standing before a judge, he will care little of what we think here. He will care to remove money from your wallet though.
Re: Mass in motion
01/10/2009 1:51 PM
Your probably right, but if i could dazle him with a formula proving that there is no additional force to the road surface because of the speed, he might not hammer me as hard. allways worth a try.
Good Answers: 73
Re: Mass in motion
01/10/2009 1:59 PM
"he might not hammer me as hard"
Ya, right, actually he will hammer you harder, for waisting his time, and being a smart-ass.
You must be young, (not a bad thing). Tickets are written for "revenue enhancement". Once they get you in court, well, let's just say they turn you upside down, grab you by your ankles, and shake baby shake!
Good Answers: 88
Re: Mass in motion
01/10/2009 1:48 PM
Where the truck's wheels "land" deforms the road surface at the point of impact. The effect is most pronounced in composite surfaces such as asphalt, where the surface is pushed slightly ahead of the wheel, producing a depression in the road surface at the impact point, and a bump at the forward edge of the impact area. The bump causes a second vertical displacment in the vehicle's wheels which creates another impact point further on, and the process repeats, eventually creating a "washboard" surface in the composite. Impacts by subsequent heavy vehicles will cause additional surface displacement and deterioration at each impact site. Eventually the sites become potholes which must be repaired.
As the structure under consideration is a bridge, additional factors come into play, such as structure deflection and resonances. First and second-order resonances can place the bridge deck under tension, causing cracking and deterioration in both composite and concrete surfaces. Vehicle weight and speed become critical considerations because certain vehicle speeds may accentuate the amplitude of the resonance, introducing additional deck flexure. If the flexure neutral axis is located some distance beneath the deck surface, cracking will be more pronounced. Cracks introduce water which can freeze and expand the crack during the winter months, accelerating deterioration in the deck surface.
Good Answers: 73
Re: Mass in motion
01/10/2009 1:53 PM
Good points there euro, well thought out. However, I don't remember seeing any potholes in Germany. Maybe there illegal there!
Good Answers: 88
Re: Mass in motion
01/10/2009 1:55 PM
Germans are a strong-willed people, generally. They simply forbid it!
Potholes? Verboten!
Good Answers: 25
Re: Mass in motion
01/11/2009 1:56 PM
Actually the pot holes are still there. They have developed an invisible filler for the holes and now they have mfg. so much of it they can cover the whole darned road with this stuff. But: as always there can be too much of a good thing. They covered a test section of the Autoban with this stuff one afternoon and by the next morning it had disappeared. Shortly thereafter the creators ,mfg's, and installers had all disappeared.
Now I never did get it straight as to whether it was the autoban that disappeared or the disappearing pot hole filler that disappeared. I do know for certain that the pot hole filler that we use here in the good ole U.S. of A. disappeares right before your eyes.
TMF
The only problem with common sense, is that not very many people have it, or know how or when to use it.
Re: Mass in motion
01/10/2009 1:56 PM
Well europium, you just convinced me i need to keep to the speed limit, however i might see it.
I wish they were verboten
good answer!
Good Answers: 123
Re: Mass in motion
01/12/2009 12:19 PM
Perhaps you could convince the judge that you had lowered the pressure in your tires so as to soften the pounding the bridge would take.
Bob
Good Answers: 15
Re: Mass in motion
01/11/2009 9:09 PM
Please bare with me, I'm typing with 1 less finger (a slight modification with a griner and a slitting disc)..
Oh well, If your curious about the damage heavy vehicles do to the road pavement, check out asphelt roadways that heavy trucks frequent, it's not the pot-holes that you have to be careful of, but the channels that the trucks cause over time as the road pavement is slowly pushed out to the sides of the tyres as the trucks drive along those roads.
Also the "pulling" effect on the roads when trucks take off from traffic intersections (noted by the painted lines on the roads indicating the lanes and crossing lines)
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Good Answers: 88
Re: Mass in motion
01/12/2009 12:22 PM
"Please bare with me, ..."
If you remove your clothes, be sure to mark your post "off-topic" and keep an eye out for the CR4 Admins.
Re: Mass in motion
01/14/2009 10:46 AM
I helped develop a bridge testing system. A truck rated at 80,000 # GCW could carry 200,000 # ar 2 mph. Note this was the truck rating, not the road rating, but the principle is the same. Low speed = low impact = less fatigue.
Re: Mass in motion
01/10/2009 3:34 PM
europlum wrote:
"Cracks introduce water which can freeze and expand the crack during the winter months, accelerating deterioration in the deck surface."
Why do cracks also get enlarged when it is continually above freezing like Summer time in wam climates?
Bud Trinkel
Good Answers: 73
Re: Mass in motion
01/10/2009 3:42 PM
"Why do cracks also get enlarged when it is continually above freezing like Summer time in wam climates?"
Perhaps vibration breaks material away and then there's erosion from rain water.
Good Answers: 88
Re: Mass in motion
01/10/2009 4:06 PM
The roadbed expands and contracts over the course of each day because of changing temperatures. In hot, arid climates the temperature difference between day and night can be quite pronounced, aggravating the situation. This movement places additional stress on the road/deck surface which is weakest where it is already cracked.
Furthermore grit, sand, dirt and such can lodge in the crack, keeping it from closing during the expansion phase. This material can function as a fulcrum, with the sides of the crack acting as two levers. As the surface expands (the expansion is differential due to the temperature gradient between the surface and parts farther down) the bottom of the crack is forced open, driving the crack deeper and forcing it to propagate laterally.
Re: Mass in motion
01/10/2009 6:58 PM
Momentum, not weight, is the concern.
Hold a brick over your head and run, then stop suddenly.
Now, same thing, only from a swift walk. Now you see the issue from the perspective of the bridge.
If I were you I wouldn't be so worried about the judge, but about the bridge. I'd hate to be held in contempt by a bridge since the fine could be much steeper, so to speak.
I do not 'know it all', but i will admit that I would like to. CJM
Good Answers: 88
Re: Mass in motion
01/10/2009 8:21 PM
"I'd hate to be held in contempt by a bridge since the fine could be much steeper, so to speak."
I'll bet you got good grades in your civil engineering classes.
Re: Mass in motion
01/10/2009 8:36 PM
Since high school was the last degree, though I've had a variety of coursework since. I'm actually considering pursuing the paper-on-the-wall just for the legitimacy aspect. Now that I've retired I have the time.
Good Answers: 88
Re: Mass in motion
01/10/2009 8:38 PM
Go for it!
Good Answers: 70
Re: Mass in motion
01/11/2009 2:32 PM
I believe you need to consider Mass X Velocity Squared. 60 squared is 3600, 80 squared is 6400, so at 80 km the force of the truck tires 'crashing into' small bumps in the road surface (and also small bumps on the tires crashing into the road) is roughly twice as great.
Good Answers: 88
Re: Mass in motion
01/11/2009 2:41 PM
The force applied to both the tires and the road surface is considerably greater if the vehicle is braking while traversing the bumps. Best to slow down first, then release the brakes before reaching the damaged area.
Re: Mass in motion
01/11/2009 8:16 PM
And this is for a bridge in a straight line, most have turns and changes in slope. The vector forces are 1.777 times positive or negative to the bridge by the change of the additional 20Kph when you turn or increase your climb/Gee ratio.
F=V2*M/2 put a damper on many of my faster ideas.
Brad
Re: Mass in motion
01/12/2009 9:02 AM
It should be the same, because the velocity travelled is a force tangent to the road. Therefore, the weight would be the only thing that would cause a change in force applied normal to the road. This can be seen by:
sum of the vertical forces = weight*gravity
Good Answers: 25
Re: Mass in motion
01/12/2009 12:29 PM
The equasion isn't all that simple! One must consider that the various shapes of vehicles will cause different down forces upon the surface traveled even with out the natural hammering that occurs as the vehicles suspension system constantly adjusts for a more comfortable ride of vehicle occupants. Further is the lateral forces that occur as the tires wander around in the rutts, as no road is truly flat. Additional stresses occur as said vehicles pass around curves.
Where ever the surfaces change like bridges vs roads the bridges will flex as they are not as stable as the well compacted materials that create the road bed. Temp. changes also effect the movement of the bridges as well as the road surfaces and do this differently.The combination of all of these and more differing conditions is accentuated by speed. Nuff said about this subject!
TMF
Good Answers: 119
Re: Mass in motion
01/12/2009 1:40 PM
I think you must consider time as a factor in your initial question. What may not be a problem on day 1 may be catastrophic on day 1000 on any particular driving surface.
Consider as an example a highway constructed of reinforced concrete slabs of x length. A heavy truck entering the slab pushes down the slab at the forward end. As it reaches the end it "rocks" the slab in the opposite direction, very minutely on a newly constructed road but progressive with use. After many iterations the rocking motion becomes exacerbated as the underlayment breaks down and allows additional vertical motion near the ends.
Extrapolate this to the individual "decks" of a bridge and you can see that the weight of the truck combined with the speed it is traveling can make a huge difference in the stresses involved.
If this is hard to believe, it was easily displayed on Interstate 696 between Detroit and Port Huron, Michigan about 10 years ago when I lived and worked there. The state allowed trucks way too overweight for the design of the road for years. Traveling on the road in a car at a resonant (to the slabs) speed could actually result in a very squeamish, annoying and potentially damaging up and down movement along the slabs.
Hooker
Register to Reply 31 comments
Amilo630 (4); bob c (1); Bricktop (5); BudT (1); CJMcGill (2); HarryBurt (1); Hooker (1); johnfotl (1); nathaniel1105 (1); not so smart (1); sb (1); Snaketails (1); Toomuchfun (2); U V (1); user-deleted-13 (8)
