Previous in Forum: Two Rotor Induction Motors   Next in Forum: Earthing Conductor
Automatic water pumping control system with alarm indicator
10/27/2006 3:27 PM
Kindly help me to get a reliable circuit diagram and a suitable writeup for the project titled "Automatic water pumping control system with alarm indicator" I will be very glad if i can see somebody to help.
The Feature Creep
Re: Automatic water pumping controy system with alarm indicator
10/27/2006 3:36 PM
I'm assuming that you are looking for a data sheet and diagram. You can look for one here. You'll have to enter some specs to narrow down the type, but it should help.
"The future is here. It's just not widely distributed yet." -William Gibson
Re: Automatic water pumping control system with alarm indicator
10/27/2006 4:46 PM
What i want is functional circuit diagram with little writeup for the project
Thanks
10/27/2006 9:53 PM
?So you have to make clear, what quality do you want to control? over voltage or current? or flux? or rotation speed.
you can use an inverter for most control of the pumper.
10/28/2006 7:33 AM
What exactly Sir, do you wish to know about
automatic water pumping control system?
I could propose one to you.
Teddy Iyke
10/28/2006 4:52 PM
Dear sir,
i wish to know about automatic water pumping control system. If yu have any circuit diagram and full detail of explanation on it just like writeup for project, pls kindly send it to me.
Thanks very much
BRodda (1); cnpower (1); teddy (1); tuns (2)
