Previous in Forum: 3525 OSCILLATOR CIRCUIT   Next in Forum: I want to google my lost dog w/ GPS chip on his collar
Cisco Switches - 3750 Series
01/13/2009 10:42 PM
Hi all,I have configured 2 cisco switches of 3750 series.port 9 of switch 1 is connected to the port 9 of switch2.both the port is in up condition.but the status leds at port 9 of switch 1 is steady green and port 9 of switch 2 is steady amber..why is it so?can any one let me know the reason for it..
Thanks in advance
Good Answers: 50
Re: Cisco Switches - 3750 Series
01/15/2009 1:00 AM
First, does each of your configurations contain the command "no shutdown?" Second, check your cable. You may need either a cross-over cable or a straight-through cable. If you're using the wrong one the connection won't work.
Good Luck.
01/15/2009 1:07 AM
hi,
thanks for ur reply...the problem is solved..it is due to some misconfiguration of vlan..
Register to Reply 2 comments
