Previous in Forum: Fire Fighting system for Transformers   Next in Forum: Voltage Variation Compared to Current Inductor
DG Set Rating
01/15/2009 8:53 AM
Are there any derating factors to be considered while sizing the DG set? If the prime rating of DG set is 500 kVA (i.e.400kW), can it be used to cater 400kW load? I have seen people normally consider only 80% loading on DG sets i.e. in requirement of 400 kW back up, 500kW (625 kVA) rating of DG set will be selected. As per my consideration, DG set of 400kW (500kVA) prime rating can be provided for 400 kW requirement of load. Pl. advise.
Pathfinder Tags: DG set rating
Re: DG Set Rating
01/16/2009 3:59 AM
Dear Mr Bharat,
When a D.G set has been designed for 500 KVA obviously it has to give an out put power of 400 KW at 0.8 pf provided its run in ideal condition of supply of adequate amount of cool air, complete exhaust of the hot air emanated both from the engine as well as the alternator. The D.G set has to run at the designed limits of ambient temperature, humidity and altitude. The engine is water cooled where as the alternator is air cooled. Therefore cool air has to be force blown to the fan side making the exhaust of hot air from the winding completely out such that the generator room temperature is same as if the generator is standstill. This condition is not possible practically. Therefore we take the safety aspect & derate it to 80% of the KVA rating.
Re: DG Set Rating
01/16/2009 10:01 AM
Thank you for your guidance. As far as temperature is concern, there is a temperature rise test in standards and it has to be taken care that the values of this test are within the limits. And normally, in the manual of DG sets, only a 'well ventilated' room to be provided and forced ventilation does not of their demand. As you say, it seems that 80% loading on DG is only a safety aspect otherwise it can be loaded fully upto it's rating as per the prime rating calculations.
Good Answers: 213
Re: DG Set Rating
01/16/2009 7:55 AM
Most generator manufacturers provide guidelines for derating their equipment based on use as standby/prime supply, higher power factor, ambient temperature, altitude, etc. Usually the owner/operator manual includes such guidelines in the initial sections of the manual. There is some variation between recommendations of different manufacturers, so it is best to consult the manufacturer directly. I have encountered machines from some lesser known manufacturers with totally inadequate literature, but I do not expect this to be a problem in the 500 kVA range...Start with the manual, or consult directly with the manufacturer.
Register to Reply 3 comments
Bharat_Prajapati (1); cwarner7_11 (1); SABNAVEES (1)
You might be interested in: KVA Meters, Loading Arms, Power Frequency Converters
