Previous in Forum: 1998 Chevy Cavalier and Cold-Weather Starting   Next in Forum: Leaks in CNG Pressure Lines
12 comments
2000 Chevy Cavalier Starting Issue - Power / Electrical
01/15/2009 4:27 PM
OK. Thanks in advance. Was driving my car, and came to a stop at a red light, and it just died. All guages went off and the car was no longer running, but the radio remained on. Pushed it off to the side and got towed home. Tried to start in both neutral and park. When the key is turned forward (ON), the guages do not turn on, and it appears as if there is no power. Normally when turned forward, the gas guage goes up and the temp guage. But now, there is no power to this. The radio will still turn on. (Yes... there is gas)
The tow truck guys tried to help, and said this was the first time he's ever been absolutely baffled. We checked all the internal fuses, and the ignition/battery fuses under the hood. Tried to jump it to the battery and to the starter, but there was still no sign of power. Anyone have any ideas out there?
Re: 2000 Chevy Cavalier Starting Issue - Power / Electrical
01/15/2009 7:50 PM
ACS,
Sorry but you probably have a chip issue. Off to the dealer you must go!
Location: Milky Way galaxy, Sol solar system, Earth (not Giaha), USA, WA, N.E.
01/15/2009 8:04 PM
OK, there's some missing info here.
Does the battery have any charge in it? Check first by turning on headlights. Next, using a test light, check it between thr posts.
Next disconnect the ground side of the battery and, with every switch off, check between the cable and post. If it lights the test light you have a short to ground. (Note: the vehicle computer may draw a sleight amount, causing a dim light).
If there is no major draw there I would suspect an alternator problem or a battery that has become sulphated or otherwise become inoperable. Try another battery at this point.
If there is a major draw, get an auto electrical expert to check it for you. You may limit the damage that way.
They that do not learn from history and apply those lessons to the present are bound to repeat its failures.
01/16/2009 12:06 AM
If the radio works with the ignition key in the off position, then it sure looks like the ignition switch is bad. All of the gauges are energized through the ignition switch... sometimes including the radio and sometimes not.
This is it... so live it up!
01/16/2009 12:37 AM
Actually, now that I rechecked it. The radio can turn on and off, but doesn't come on when the key is forward. Only backward.
01/16/2009 12:41 AM
If so, then that leads us right back to the ignition switch. Perhaps a short in it.
How old is the vehicle? Also, when you said that you had jumped to the starter, did you mean that you had jumped from a different vehicle's battery directly to your vehicle's starter?
01/16/2009 12:45 AM
2000. That makes sense for no power going to it to turn it on, but does this also explain that it died while running?
01/16/2009 12:53 AM
Yes, and it's easily tested when one knows how. The electrical part of the switch has relatively small parts that can wear out and fail. The non-start problem can be solved by the process of elimination, and the obvious is to prove or disprove the operation of the ignition switch first.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Manufacturing Engineering - Member
Location: Honeydew, South Africa, 26° 04' 50" Lat, 27° 54' 59" Long
01/16/2009 2:30 AM
I am no expert in auto electrical but what about a faulty ignition relay?? They are usually at or near the fuse box, sometimes in a black box in the engine compartment. Worth a try to check it out.
Make The Most Of It.
Good Answers: 97
01/16/2009 4:23 AM
symptoms typical of torque converter solenoid failure
01/16/2009 8:27 AM
Wow, Ignition switch problems have been reported (I had one) and also DEAD (shorted batteries cause this. It may be broken inside. Just another defective part. It WILL NOT JUMP if the battery is shorted. Another battery will test it.
Ray Cockrell (again)
01/16/2009 10:30 AM
OK, So I will try these things. I'm not really sure what Ray Cockrell was talking about though. Wouldn't a dead/shorted battery no longer power the lights and radio? Also, wouldn't this not cause the car to just shut off like it did?
01/16/2009 7:08 PM
First., A dead battery wont stall an already running engine . You already said you tried to boost it and no go . Your battery is not the problem. You have a open circuit somewhere in the " run " circuit of the car as you said the radio works with the key in accy. position .
Second ., Try to determine where the open is by following the small, "not big" diameter wires coming from the batt. pos. terminal . These wires supply power to the "run" system of the entire vehicle and theyer might be more than one , these wires have a bulge in them that contain a " fusable link " , these act like simlple fuses so probe the wires after the bulges with a test lamp and check for voltage . If all is ok go to the underhood fuse panel , unbolt it and carefully turn it over to see all the connectors , look for a burned and or loose connector. If all is good you probably have a bad ignition switch , check by slowly turning key back and forth , off and on and observe the gauges for power . If no go remove ignition switch and check for burned connectors at the back of the switch.
Good Luck .
What dosent kill you makes you stronger , lifes a trip so sit back and try to enjoy the nice scenery.
Register to Reply 12 comments
ACShoops33 (3); bwire (1); Conrads (1); machine head (1); ray cockrell (1); Rock1 (1); Shadetree (1); Skeeter (3)
