Hi
I ahve one question need discussion,
Let is say that we have a 120 m 6 " pipe (new one) and this pipe has 18 welding point, the design code is B31.3 and design pressure is 20 kg/cm2.
the hydrostatic test was ok 30 kg/cm2. But the radigraphiy test has 16.6 % of total weld joints has fail.
and for critical operation we need to run this pipe urgently.
So is it possible to run this pipe depending only in Hydrostatic test without X-RAY.
but what we have to do??? for X-RAY we will do it later.
the working pressre is 16 kg/cm2 and the fluid is flammble.
