Previous in Forum: In service pipe thickness limits   Next in Forum: Chiller's
Gas Pipeline
01/17/2009 11:54 PM
Why drying is required for Gas pipeline? what are the types of drying?
Re: Gas Pipeline
01/18/2009 4:14 AM
Dear Krishnan,
Water inside a gas pipeline in operation causes a number of problems (internal corrosion).
You can check in Google full info...
For example:
http://www.ceps-as.cz/suseni-en.html
B.R.
In-line Inspections for pipelines, diagnostic and NDT
Good Answers: 120
Re: Gas Pipeline
01/18/2009 11:37 PM
Gas and water under pressure can form clathrates, or hydrates.
http://en.wikipedia.org/wiki/Clathrate
these are solids and an accumulate and block pipes, and break compressors etc
Per Ardua Ad Astra
Re: Gas Pipeline
01/19/2009 2:01 AM
Hi Krishnan,
You require a dry gas so that during rapid decompression and subsequent cooling(Jule-Kelvin effect, adiabatic expansion) the line will not become blocked due to the formation of ICE.
Hope this helps.
To achieve a dry pipeline it has to be correctly precommisioned by pigging or vacuum drying. Any gas introduced into the pipe has to be up to spec regarding its dryness.
Re: Gas Pipeline
01/19/2009 2:49 AM
from a corrosion point of view is necessary to avoid internal corrosion. if you can dry the gas to achieve a dew point lower enough to avoid any condensation then you can consider you gas as non-corrosive.
This is taken from the Norsok M-001 Material Selection for Oil&Gas.
"A gas is considered dry when the water dew point at the actual pressure is at least 10 °C lower than the actual operation temperature for the system."
" For pipelines with dry gas or non-corrosive fluids, no corrosion allowance is required."
hope this help
V.
Good Answers: 120
Re: Gas Pipeline
01/19/2009 3:18 AM
gas hydrate plugs show up as a pipeline problem that must be guarded against
http://www.google.ca/search?hl=en&q=%22gas+hydrate+plug%22&btnG=Search&meta=
Per Ardua Ad Astra
ANDREI (1); aurizon (2); Stewie (1); strider6 (1)
