Previous in Forum: Installing Sematic S7 softwere   Next in Forum: MATLAB Tutorial for DSP
Interface with MsProject from MsAccess
01/19/2009 5:06 PM
How do I interface with MsProject from MsAccess? I created a MsProject document outlining work schedule of different work activites and thought it would be interesting if I can relate to the specific data values in MsProject (i.e specific work activity, start date, finish date, percentage of work completed, etc) from MsAccess (these data values are automatically copied to Access file.)
Re: Interface with MsProject from MsAccess
01/21/2009 8:36 AM
First and easiest might be saving your MPP file as an MDB file. The MDB tables could then be linked into another MDB file that you use to analyze the Project File.
The original MDB (saved as) can be opened in project. Just scroll down to the .mdb option in the file type box.
A more involved method would be to us MS project object. To share data between the applications you will need to work with the MS Project API (I am assuming you already work in the Access API). A couple of links to the Project Object Model are:
http://www.aspose.com/Products/Aspose.Tasks/Api/Aspose.Tasks.MPPFile.html
http://hearwhat.blogspot.com/2004_03_01_hearwhat_archive.html#108028565677237750
Good Luck.
