Please help me figure out the pneumatic circuitry needed for an assembly fixture. It will contain two small double acting cylinders (Cylinders A & B) that will need to actuate both independently and simultaneously during the 3 step assembly process described below:
Note: Cylinders A and B are both retracted in the default fixture position.
Step 1: Actuate two hand control unit: Cylinder A to extend and hold; Cylinder B to remain retracted. (Parts will be loaded into the fixture and extended Cylinder A will insure proper orientation)
Step 2: Actuate two hand control unit: Simultaneously, Cylinder A to retract and Cylinder B to extend and hold. (Remainder of device assembly to take place)
Step 3: Actuate two hand control unit: Cylinder A to remain retracted and Cylinder B to retract. (Assembled device unclamped and removed from fixture, which has returned to default position)
Any suggestions would be greatly appreciated. I have read some of the online training materials from NFPA, but I need some additional help to figure this one out.
Thanks in advance.
