Previous in Forum: Calibration / Metrology Training in Pennsylvania   Next in Forum: Connector to Feed a Motor Driving a Wheel
Galvanic Corrosion
01/21/2009 12:12 AM
Should I be concerned with galvanic corrosion between a 18-8 stainless steel screw threaded into a zinc plated nut where only the head of the screw will be exposed to rain, and other chemicals are unlikely to be present? If so, would a thread adhesive be useful to separate the metals, or should I consider improving the finish on the zinc plated nut, which is not available in stainless? Thank you in advance for much appreciated suggestions and comments.
Robert
Re: Robert
01/21/2009 9:03 AM
coupling SS to GS can give galvanic corrosion. If only the screw, SS, is exposed to the atmosphere, rain, while the GS-SS interface will not be exposed to water or atmosphere then galvanic corrosio is not a concern.
here you can find information on galvanic corrosion og GS
http://www.galvanizeit.org/aga/designing-fabricating/design-considerations/dissimilar-metals-in-contact
if you want to be sure you can use a isolating washer between the two materials
S
corrosion prevention & corrosion protection
Re: Galvanic Corrosion
01/23/2009 12:05 AM
Thanks for your help. I will consider a threadlocker such as loctite, just to be sure of isolating the two metals, and to make the connection stronger.
Robert
01/23/2009 4:43 AM
You mention that SS nuts are not available.
This is a surprise.
Here in Australia, there is no trouble getting SS nuts for the common sizes of bolt.
I'm sure if you checked other countries you would have no trouble getting SS nuts at a reasonable price.
Use that and your galvanic corrosion problem between nut and bolt vanishes.
01/24/2009 10:04 AM
Thank you Sceptic. Problem is the nut is a "tee nut" with a 7/8" long shaft. It is a bit unusual, but further problem is that it gets another screw inserted in it from the other end. That screw is zinc plate and it attaches other pieces that are also zinc plate. Could change the original stainless screw to zinc, but it is also unusual shape and is exposed to weather if I could even find in zinc plate.
Robert
01/27/2009 11:45 PM
Thanks. That clarifies the problem.
In that case, loctite is probably your best solution.
Good luck
Anonymous Poster (2); sceptic (2); strider6 (1)
