The current transformers typically work on low voltage and high current (based on the ratio of course) mode.
The insulation between the primary and secondary is based on the rating (like in VTs).
However tha main difference is that the CTs secondary are virtual short circuits where as in case of Vt is almost open circuit.
In case of a secondary fault - ie the secondary getting opened - a very high voltage is created in the secondry due to its large number of coils and its corersponding inductance. This voltage is usually sufficient to destry the transformer as well as breaking the insulation between primary and secondary. And you can imagine what will happen to the personnel nearby, or the person who has by error put the line switch off.
To avoid this from taking place the secondary is earthed.
